Passing Edge GUID to MatchSrf
I encountered a frustrating behavior when trying to pass an edge GUID to MatchSrf with the SelID option:
Command: _SelID
Object ID to select: eee8ee87-8906-4dc2-a48f-7da107c8cbac
1 curve added to selection.
The GUID is a valid ID for an edge of a surface. When I pass it to the SelID command directly, it successfully highlights the edge in the view port.
Command: _MatchSrf
Select untrimmed surface edge to change ( MultipleMatches ): _SelID
No objects added to selection.
However when I pass it to the MatchSrf command, the GUID is not recognized.
My end goal is to find a programmatic way to invoke MatchSrf from a python script. I couldn’t find a way other than using the rs.Command on “MatchSrf”. However the above behavior blocks this approach too.
Any insights are appreciated!
Hi @Yulin_Li,
Brep edges do not have ids.
– Dale
Can you provide a simple .3dm file with the object you want to edge highlight?
Hi Terry,
I’m not trying to do this task interactively. I have written a python script to create surfaces programmatically. Basically:
brep = rg.Brep.CreateEdgeSurface([crv1, crv2, crv3, crv4])
However, when I need to match two surfaces thus created, I don’t see an API for it in the SDK. I tried to work around it by calling this in python:
success = rs.Command(f"_-MatchSrf SelID {guid1} SelID {guid2} _Mode={mode} _PreserveOtherEnd=Nothing _MatchByClosestPoints={match_by_closestPoints} _RefineMatch=No _AverageSurfaces={average} _IsocurveDirection={isocurve_direction} _Enter", echo=True)
This doesn’t work since the edge guid is not recognized.
Hi Dale,
Please see my reply to Terry. Is there a way to invoke MatchSrf functionality from within python?
Hi @Yulin_Li,
Try using Brep.CreateFromMatch.
– Dale
Hi Dale,
Thanks! I will give it a try.
