Passing data from .net to Rhinoscript
Is there an example of how to do this in Rhinocommon? VB.net preferably.
Thanks,
Don
Are you trying to expose functions in a plug-in to RhinoScript? If that is the case, we don’t have a RhinoCommon specific example yet, but the procedure is almost identical to how it was done in Rhino_DotNet
http://wiki.mcneel.com/developer/sdksamples/extendrhinoscript
You would override
Public Overridable Function GetPlugInObject As Object
in your plug-in class for this.
it is failing on the script side when I run:
Set objArray = Rhino.GetPlugInObject(“MyScriptHere”) 'fails here
I have ComVisible set on the .net side:
<System.Runtime.InteropServices.ComVisible(True)>
I’ve been tweaking it all morning, I’m stuck.
Thanks,
Don
Is “MyScriptHere” the name of your plug-in? Is your plug-in installed so Rhino knows about it?
No, “MyScriptHere” was just for the example.
It is installed but somehow the name had been truncated when I went into Options>Plug-ins, I fixed that in the assembly file, and it shows up correctly in the Plug-ins list now, but it is still not working.
I found the issue, at some point, somehow, I had deleted:
Thanks for your help
Whew. I was scratching my head trying to figure out what the problem was here. Thanks for letting me know
