Hey @Pascal,
I wonder if you could look at the attached screencast video and tell me what I am doing wrong in running your Silhouette_Vp script?
Thank you.
Hey @Pascal,
Thank you.
Hi Cosmas - - nothing wrong I would say except that if you are snapping to the camera points for the direction that will end up doing what Silhouette does anyway. As for the output, this script just ends up running the Silhouette command from the direction you pick, and whatever the command gives back- including all surface edges, is what you get. V6 Silhouette does understand that you really want the overall silhouette and probably not per-face and allows you to get that result…
