Partial Brep Split is possible
hi All,
is it possible to split partial brep
here in the script the full Brep is split into 2 parts
actually am looking how can i split partial is that possible to split ?
thanks
rajeev
BrepSplitPartial.gh (129.5 KB)
I don’t understand what you are tring to achieve.
Two things however:
  1. The Shift Path component isn’t necessary
  2. Instead of using a Plane Surface, use a Plane Through Shape. No need to specify the size.
thanks @martinsiegrist
actually my question in split Brep component
the split splitting of the Brep will be based on the cutter shape
instead of plane or flat surface i can give a different shape and it may split based on the cutter shape
thanks
rajeev
