I’m trying to make a doorframe using sweep 1 command.
It appeared fine in the preview:
But after I pressed “ok” the right part is gone:
Tried deleting the skirting beside it to see if it was because of the neighbouring skirting insecting with the doorframe, but problem was still not solved:(
doorframe 2.3dm (2.0 MB)
Explode the door frame polysurface and run SelBadObjects. Several of the surfaces are “invalid”. How did you create those surfaces?
When uploading a file it is best to only include the parts which are directly related to the question.
Thank you for replying. I am new to this community so thanks for the reminder
I created the shapes by drawing rectangles then replace front part of the rectangles with arcs:
<-top view
I created the doorframe by tracing the outer edges of the shapes aforementioned then connect it to a “rail”:
How did you trace the outer edges of the shapes? Which commands did you use?
Can you post a file with the curves you used for creating the surfaces?
I think I used dupedge.
Here is the file. I kept the skirting and floor for reference.
doorframe 3.3dm (1.94 MB)
