I will have to try to respond to some of the other events yes, and then do the connected-check from there. I just tried GrasshopperDocument.SolutionStart += OnSolutionStart; but got no response from there either.
If I’m right, you’re misunderstanding the origin of the event. It does not happen when the parameter collects data, but when the parameter server makes a change (adds or removes a parameter). Parameter here means input or output, not the data coming in or out.
On your other question, I wouldn’t be at all surprised if the source component doesn’t update its recipient links when the connection happens, what need does it have to do that? This only requires knowing the recipient links when updating the status of their outputs, and this happens when the component expires. But well, I can’t affirm this, just speculate.
It doesn’t fire the event when connecting (adding) or disconnecting (removing) a wire (leading to a parameter). I don’t know of any other way of understanding this.
For optimization. If outputs are not connected, then no need for producing the output data (which no one is using).
I think I understand the difference between the data in the output param and it’s connections (Recipients), but changing either doesn’t fire the proposed event, at least not as far as I can se.
I hope you understand better with code than with words then. Try this out
this.Component.Params.ParameterChanged += (s,e) => RhinoApp.WriteLine("PARAM SERVER HAS CHANGED");
And change the type of access of an input. This event has nothing to do with the wires.
I don’t think you’ve thought twice about that. It is not optimal to have to expire the component when a recipient is plugged in, because there is no need. The output only changes when the inputs change (assuming there is no other mechanism to affect the process). The source component is not responsible for sending the data, it is the recipient component who reads the sources.
Wires are links between parameters. Sources (outputs) and recipients (inputs) are parameters. Parameters are spaces to place arguments to be readed (inputs) or writed (outputs) by the component. Arguments are the data or values that are communicated from one parameter to another through the wires (in a visual representation). GH does not have an event when the data of a parameter changes, because it is not easy to do it optimally I suppose.
It makes no sense for me to try to convince you, I can only give my point of view, and without any thanks this ends here for me.
yes, and i donä’t want to produce any data, nor output any data, if no downstream component is connected. That’s an optimization scheme used by some of the std grasshopper componetns as well.
And?
This is the code I use to test whether the output has recipients. (it is Inputs that has Sources, and Outputs has Recipients).
has_recipients = param_G.Recipients.Count > 0; // output is connected;
In my code I read the Output Recipients as demonstrated below (and I also read “Output Sources”, which doesn’t exist, just to prove that it doesn’t exist - for Outputs) and I output the result of the check visibly in the picture below the code (the recipient counts).
Fig 1. Only the params.Output.Recipients return a value > 0 (due to the fact that a wire is connected)
Why the expected events aren’t firing, though, is not explained by your take on “Input Receivers” and “Ourput Sources”, which obviously isn’t correctly paired (they need to be swapped).
But now the thread diverted into a completely irrelevant direction. Therefore may I suggest that you drop the Source/Recipient confusion and let someone answer who knows why the corresponding events are not fired. I can understand if the event for one (1) of the cases isn’t fired ((for value change, or for connecting wires, since the documentation isn’t 100% clear about whether it fires for either), but if not fireing for any of them then…
Well, that was my question (no event fired in any of the cases). And to be clear: This is not a question about whether it is a good idea or not to check the Output Recipients (it IS a good idea). My question is only about being notified when connecting/disconnecting happens. @DavidRutten would know more about this.
Now I have tested and double checked the original code which I posted in the first post (I only added writing also to the Rhino command line), and of course I’m doing the test-coding perfectly right. And if the problem wasn’t clear before Mr D. Abalde messed the whole thread up, this is the problem stated in correct and crystal clear terms:
Changing the number of Output Recipientsdoesn’t fire the expected event, although…
Changing the number of Input Sourcesdoes fire the event.
Of course anyone can run the code below, while adding or removing wires for Inputs and Outputs respectively, and find out that only when changing the Input wires the Params will fire its event “OnParamsChanged”:
So, the problem is there, and the original question remains - or perhaps better asked; will mcneel (@DavidRutten, @stevebaer) consider adding the firing of the events asked for in this post?
(And please disregard any confusion and “strong opinions” about the usefulness of being notified about the Output Recipients (wires) being changed. It is useful, but if there’s another way to achieve the same thing I could of course go for that other solution instead).
It seems obvious that, if adding events also for Outputs, that the events should be separate from the Inputs as to not break existing applications (by firing event’s that wasn’t there before).
The following (similar) events should be fired also for Output params:
@Dani_Abalde is correct. It’s related to changes to the parameter objects themselves. Adding or removing recipients is not considered something that affects any parameter.
There’s an additional problem doing this in a script component. When a parameter (be it input or output) is added, removed or renamed the script will be recompiled. So your event handler is now running inside an assembly which is no longer the one the script component cares about.
Well, it affects parameters in the way I described it, namely that if there’s no recipient = then no need to process data, or to output any data. So there definitely are reasons to add events also when changing the connections to Outputs.
And this is also why I asked for the event, and I would have preferred staying on that particular topic (not Mr Abalde’s).
For some reason it also works with ParameterChanged (for inputs) but if ObjectChanged is preferred then thanks for the hint.
Edit: Problem is, when I commended away ParameterChanged and replaced it with ObjectChanged, then the update stopped working (no events firing). So I really don’t know what you guys are talking about. You are obviously not on my topic.
Here’s some code which allows you to keep track of changes to input sources and output recipients. There’s a lot of it sadly… topology events.gh (6.8 KB)
I disagree. You should always compute the data inside an output because it’ll be on screen and people will want to be able to see what’s in there using a tooltip even without anything connected. If an output is often unused yet takes a long time to compute, you should either create two versions of the component (one with, one without, same as the Area and Volume components), or make that specific output removable via the variable parameter interface (which would be very undiscoverable).
Yes I think even though it breaks the principle of least privilege or whatever-its-called, for symmetry’s sake it probably makes sense to add events for both source and recipient changes.
I looked into your code, and yes, I see the strategy. A bit verbose for that little thing, but so what, it works.
It depends very much on what the component is doing. Also I didn’t say I would always skip preocessing the solution altogether but I have several cases where writing to an output is optional, but increases the execution time with almost 50%. One example was a component checking for nearest point for a number of breps. A thousand points took 24 ms and has 2 mandatory outputs, A third (optional) output increased execution time to 32 ms. That’s a typical case where removing a wire (would have made) a huge difference.
Oh yes I’d forgotten that the Params object handles and re-emits all parameter events. This was done so you don’t have to deal with each input and output individually as I did in my example code.
But, I don’t see any events fired for Outputs, only for Inputs. In any case, Outputs should have their own (new) events so as to not break existing code out there.
