hi guys… I was wondering if it is possible to do something like the image below… defining points that could be easily altered do create different forms but with the same “appearance”
I am having trouble to find out how to create this kind of loft with this different shaped arcs…
any idea or command that would be useful?
thank you
i was able to build this but the lofting is very weird…
You can control the Z deviation by adjusting the range input on the Random component. You could use a graph mapper for more control.
here’s a better version using the graph mapper: tree_loft_graph.gh (15.1 KB)
tree_loft.gh (14.7 KB)
this is awesome!
I am having some troubles with the lofting part when i change the shape too drastically… but the code works very well. If I figure it out how to solve the lofting problem I will let you know
Thank you very much!
