Parametric Spiral Vase Fuselage Structure in Rhino / Grasshopper
I am developing a large RC flying boat (PBM Martin Mariner, approximately 2500 mm wingspan) and I am looking for a parametric Rhino 8 / Grasshopper workflow.
The objective is not a conventional shell with infill.
I am using Aero ASA and have verified on a 308 mm tall stabilizer that a custom internal structure can be sliced successfully in Bambu Studio using Spiral Vase mode.
The main reason for using Spiral Vase is:
  • no retractions
  • minimal stringing
  • high print quality
  • faster printing
  • very low weight
Structure Rules
All printed elements are designed with the same thickness:
  • Outer shell = 0.45 mm
  • Inner shell = 0.45 mm
  • Internal reinforcement = 0.45 mm
The reinforcement is formed by two sinusoidal webs located between the inner and outer shell.
The sinusoidal webs touch the shells at defined locations and approach each other at the center, but a small gap (~0.001 mm) is maintained so the slicer still recognizes separate contours.
The geometry is arranged so the entire cross-section becomes a single continuous closed loop suitable for Spiral Vase slicing.
This concept already works for relatively constant airfoil sections.
The Challenge
The fuselage is much more complex because:
  • cross-sections continuously change
  • curvature continuously changes
  • nose and tail taper significantly
  • shell spacing may vary
I would like to generate this structure parametrically from a SubD fuselage while preserving:
  • 0.45 mm shell thickness
  • 0.45 mm reinforcement thickness
  • exact shell contact points
  • continuous Spiral Vase topology
  • watertight geometry
My Main Question
What would be the best Grasshopper approach for generating a continuous sinusoidal reinforcement structure between two non-uniform fuselage surfaces while preserving these geometric rules?
My current idea is:
SubD Fuselage
Generate Sections
Create Inner / Outer Shells
Generate Parametric Sinusoidal Reinforcement
Maintain Single Continuous Loop
Export for Spiral Vase Printing
Has anybody tried something similar for lightweight aircraft structures or variable cross-section shells?
Additional information:
I will attach:
- the Rhino 3DM model of a stabilizer where this concept has already been tested successfully,
- my current Grasshopper experiment for generating a section.
The cross-section concept was developed manually over several weeks and has already been validated for Spiral Vase slicing in Bambu Studio.
At this stage I am not asking whether the concept itself works.
The main question is whether a similar topology can be generated parametrically in Grasshopper f
or a fuselage with continuously changing cross-sections.
I have reached the point where I can design the structure manually, but I am struggling to determine whether this can be converted into a robust parametric workflow based on a SubD fuselage model.
prepazka cez grass v grassopperi.gh (18.0 KB)
prepazka cez grass.3dm (228.3 KB)
elevator for rc seaplen for vase mode working.3dm (954.6 KB)
Try search the forum for ‘vase’ there are dozens of topics.
There is also a tag ‘lamp’ used for a number of topics.
Yes, “vase mode” or a lamp are good ideas, but I’m looking for something unique. There is a bit of confusion here between the terms “vase” and “vase mode.” On this forum, “vase” usually refers to the object itself, not the printing method (i.e., vase mode or spiral mode). While people here do use vase mode as a printing method—usually for vase-shaped objects (and I have nothing against vases)—my model looks nothing like a vase and presents many challenges I need to solve. I chose this method because it is fast and produces a very smooth surface—which suits me perfectly—but describing it mathematically is very difficult for me.
I looked at both your Rhino files now.
If I understand correctly, the goal is to apply the structure on this fuselage?
That’s right; I’ve verified that Vase Mode works as a method for the wing profile. The wing has constant dimensions. However, I’m assuming the wing might have different shapes—either elliptical or trapezoidal.
I need to configure numerous settings so that the slicer actually applies Vase Mode when that option is selected. The wing profile might seem simple, but it isn’t. I’m currently testing this on the fuselage, and it’s proving complicated. I’m attaching the parameterization rules—or rather, the concept behind them.
concept
Just to clarify:
  1. Is your illustration of a (partial) fuselage cross-section?
  2. Are you planning to build the fuselage by stacking short lengths together?
If so:
  1. Can the sinusoidal pattern be different from one segment to the next?
  2. Do you have to include any special treatment at the joints (ie for reinforcement or increased glue area)?
Yes, it is a cross-section of the fuselage.
Yes, I plan to join the sections together. Precise alignment will be achieved using carbon fiber tubes placed in each corner on the inside—though I won’t get into the details of that just yet.
It would be ideal if the sinusoidal pattern aligned continuously, but I realize that won’t be possible, as the fuselage shape shifts to an ellipse (or a different profile) in other sections.
Unfortunately, the “Vase Mode” in the slicer doesn’t allow—or at least I haven’t figured out how—to parametrically create a 0.9 mm mating joint when the wall thickness is 0.45 mm (or when using two perimeters/walls). I need not only to accommodate the carbon tubes but also to ensure the surfaces sit flush.
Yes, a male-female joint where adhesive can be applied would be ideal. I’ve attached the fuselage shape; the green line indicates the approximate cut location, representing the cross-section profile I used in Rhino.
I have blog about this airplane on rcbuilder forum but It is from modelbuilder vie PBM 5 Martin Mariner - RC Groups
What I have achieved so far:
  1. I have successfully created the outer and inner walls (offsets) of the entire object.
  2. Between the inner and outer curves/surfaces, I can generate a center curve (Tween Curve) and create perpendicular planes (Planes) along it.
Where I ran into problems:
  • Attempt 1 (Perpendicular planes and points): I tried using perpendicular planes to intersect and find points on the inner and outer offset curves, between which I wanted to draw a wave curve and then turn it into a solid structure via Loft (with a thickness offset of 0.45 mm for printing). However, in areas where the hydroplane hull sharply narrows and turns, this approach fails—points jump around, and curves intersect or breach the boundaries.
  • Attempt 2 (Contour component): AI recommended using the Contour component. While it cuts nicely, it only works reliably on exact multiples (e.g., exactly 1 mm). If the total height doesn’t match an exact division, it skips the first or last curve, which is unusable for my case.
  • Current status: I am currently trying to solve this using Box operations/slices, but I am still struggling to keep the wave smooth, securely bounded, and safe for vase mode without crashing into the walls.
My Question / How would you approach this?
How can I properly and robustly construct a sine/cosine-like shape inside a changing 3D object so that it:
  1. Remains smooth (no sharp kinks for the 3D printer in spiral vase mode)?
  2. Does not collide with the inner and outer walls (offset boundaries)?
  3. Uses an efficient Grasshopper approach that doesn’t break down under sharp hull geometry changes?
I am attaching my current Rhino and Grasshopper files below. I would be very grateful for any advice or an example of the correct workflow!
pbm 5 sinusoida v2.gh (31.3 KB)
small section of 5 layers.3dm (117.7 KB)
Quick update and a question about Rhino/GH geometric limitations regarding Offset and Point Topology
Hello everyone, a quick update on my project. I managed to successfully generate the continuous parametric “zigzag” structure between the shells for Spiral Vase printing!
However, during the process, I hit some fundamental geometric walls in Rhino/Grasshopper that took days to debug. I realized the issue wasn’t my algorithm, but how Rhino internally handles specific topological operations.
Here are the two main hurdles I encountered:
1. The OffsetSrf behavior on drafted polysurfaces (Z-drop) When using OffsetSrf on the complex joined polysurface of the hull (which tapers upwards), the offset is calculated strictly along the surface normals. As a result, the inner surface doesn’t just move inwards, but it also slides down along the Z-axis. The mathematical UV grid drops, meaning any horizontal data extracted from it is no longer aligned with the outer shell.
2. Point topology mismatch (Divide Surface / Contour) Because of the UV shift and the fact that the surfaces are trimmed, using Divide Surface or Contour on both the outer and the offset inner shell yields mismatched results. Even if divided by the exact same number of points, the inner points miss the sharp corners, and the indices don’t align. When trying to connect them (using Weave or Join Curves), Grasshopper connects point 0 on the outer shell to a completely different location on the inner shell, resulting in a chaotic “spiderweb” crossing the entire internal volume of the fuselage.
3. Scale-dependent logic failures (Tolerance and Parameterization issues) I initially developed and debugged the whole zigzag logic on a scaled-down sample of a fuselage section. It worked flawlessly. However, when I applied the exact same Grasshopper script to the true 1:1 scale fuselage section, the logic completely broke. Curves wouldn’t join correctly, point ordering scattered, and the topology collapsed. It seems Rhino/Grasshopper’s internal tolerances, curve seams, or UV parameter domains do not scale linearly. This makes prototyping on a smaller scale and expecting it to work on the real 1:1 model an absolute dead end that cost me days of debugging.
The Workaround that fixed it: I stopped trying to generate points from an inner surface. Instead, I only extract horizontal polylines from the outer hull. I then offset these 2D curves horizontally in Grasshopper (Offset Curve in the XY plane). Finally, I use Curve Closest Point to project the perfectly ordered outer points onto the inner curve. This guarantees a 100% match in Z-height, corner alignment, and point count.
My Question to the Community / McNeel: Is there any official documentation, “best practices” guide, or a known list of these specific geometric limitations in Rhino/GH? (e.g., how UV networks behave on complex offsets, or why point mapping fails on trimmed paired surfaces). Knowing these fundamental rules would save massive amounts of debugging time. Has anyone else struggled with these specific topological discrepancies when designing printable internal structures?
Despite I found solution and working now. But this is for specific shape U . I do not know how it will work for different shape of hull for example on the top rounded .
Now I was solwing parametric walls , then parametric wave/zigzag and now is last how to closed to one continue shape. Manually I am able to but no sure how to do in grasshopper when shape can be differen on the top from botton . Tolerance is key point of clossing .
Hello! I’ve managed to create a script that works, and I understand how it functions.
However, there are a few spots that require manual adjustment, which could cause problems down the line.
At the end of the U-profile, I need to create surfaces that effectively close or connect the inner and outer shells.
To do this, I need to identify two vertical lines—one on the outside and one on the inside. I could potentially use their length to distinguish them, but that might not always be reliable. Furthermore, I need to select just one of them. The issue is that, although the B-reps are generated from a single object, the order of the curves varies, so I have to manually pick the correct one every time. The only distinguishing feature is that they are vertical rather than horizontal, but I haven’t found anything in Grasshopper that allows for filtering based on “verticality.” Is such an option available?
