Hi, can anyone teach me how to join the images together to fix the panel pieces?
The drawing is very “rough”, just to learn how to make the joints.
Is there any “automated way to do this?”
thanks
parametric_panel_test.3dm (1.2 MB)
thanks
Hi @Eduardo6,
What do you mean by “join the images together”?
Your model shows a solid object and the ribs (sections) apparently derived from it. Are you talking about learning a way to create the connections of each rib to a back panel as shown in your images?
*I remembered this recent post:
Hello, that’s right, I want to learn a way to create connections for each piece with a back panel.
Hi Eduardo -
If you need an automated way to do this, you’ll have to learn Grasshopper or some scripting language.
In plain Rhino, you’d create 2 (or more) L-shaped objects that you either join into your initial shape or to each of those individual ribs.
I already solved the problem, I did it manually and it worked.
