Parametric Layout Export of Floor Plans
Is there any way to create parametric floor plans in Grasshopper. I want to be able to export the lines at each floor in models similar to this to layout view. All the methods I have found will do a view of all the floors in the building - unable to cut the section of just the first level.
I have tried to use draft horse, however have struggled to get clipping planes to work.
I don’t want to use Make2d as this is too slow and is not very compatible with layouts.
Untitled.3dm (105.7 KB)
