Parametric Grasshopper designer: I build the generator, not just the file
Hi all,
I’m Lorenzo, a parametric designer working in Rhino + Grasshopper (trained at ControlMad Madrid, Authorized Rhino Training Center, and IED Turin).
What I do: when you have a product that needs to exist in many sizes, counts or variants, I don’t model each one. I build one Grasshopper definition where the dimensions are inputs, and the whole size run comes out of it — so when a measurement changes, every size updates instead of being redrawn.
Typical work:
  • graded product families (one object, every size), production-ready
  • parts that must assemble: real material thickness, tolerance and kerf as parameters, not baked-in numbers
  • output ready to use: STEP, STL, DXF, SVG, plus a cutting list, and the commented .gh file so you own the generator
I keep the definition tidy and documented — not a tangle you can’t reuse. I speak English, Spanish, Italian and French.
If you have a size run or an assembly problem, tell me what should stay fixed and what should scale, and I’ll tell you honestly whether a parametric approach is worth it for your case.
I also take small jobs here on Fiverr: Lorenzo P. - Parametric Designer , Grasshopper and Rhino | Profile | Fiverr
