I’m trying to create a parametric façade like the one in the image below. It has these double triangular openings, and I want to make them fully controllable in Grasshopper.
Here’s the building I’m trying to replicate the façade style of
I want to be able to:
Scale the openings
Stretch or shorten the “nose” side of the triangle
Add window frames and glass inside that follow the same shape
Maybe add some random variation across the surface
Help Guyz ?
Any example files, plugin suggestions, or workflow tips would be really appreciated
I haven’t done much yet. I just have the basic idea — it’s like a cube split in half, one side straight and the other side sloped. I’m planning to model the main shape in Rhino first and then apply the pattern through Grasshopper
