Hey there! I need help with something… I want to model something like what’s in this image. I’m using the ‘Contour’ component, but I can only get the contours to go parallel to one another. And in this case, they would need to be in a radial order.
As you can see, I first modeled the shape in Rhino, and then made the contours in Grasshopper. The red lines describe the way each contour would need to be.
by intersecting a solid (Closed Brep) with an array of large thin rectangular solids. This same method should work for you provided the bed geometry is also a closed Brep. I think you’d have to do something about the center of the array though - maybe make the rectangular solids not quite meet at the center.
