Hi Everyone!
I’m trying to write a Python Script that will parallel process a MeshRay function using the code below, but I keep getting the following error:
Runtime error (ValueErrorException): need more than 1 values to unpack
Traceback:
line 10, in script
I’m new to Python scripting, and I’m not exactly sure how to fix this. Any help would be much appreciated!
Code:
import ghpythonlib.components as ghcomp
import ghpythonlib.parallel
def meshRayIntersect(mesh):
result = ghcomp.MeshXRay(mesh, pt, vec)
if result:
return (result.point, result.hit)
if parallel:
pts, boolean = ghpythonlib.parallel.run(meshRayIntersect, meshes, True)
else:
pts = ghcomp.MeshXRay(meshes, pt, vec).point
boolean = ghcomp.MeshXRay(meshes, pt, vec).hit
