Hey there,
I have a random NURBS-curve. How do I create an elevated curve Grasshopper script from this initial NURBS-curve? The end points are specific input values, e.g 4000 and 6000 mm in Z-direction. The curve starts from a 4000 mm elevation than dips down as the parabola would and then ends with a 6000 mm elevation. Also, this curve, must follow the original planar curve on the XY-plane, so that when looking from above they look identical. Tried using graph mapper with parabola but could not managed to make sure that the end points are specific values. Original curve is attached in .gh file in case you need it.
Thank you in advance
curve-2.gh (1.8 KB)
