Paper like properties of mesh
I have two meshes which I want to use like two sheet of paper. I understand using nofoldthrough to avoid parts of a mesh from passing through each other. But how to avoid two meshes from passing through each other. For example if two close by papers are folded, when one paper touches the other there should be an opposing force and not let it pass through it. I have tried solid collide but it hasn’t given any fruitful results.
If you show what you have so far, and what you are trying to do, I might be able to help.
