Panning Delay
Idk if its the new update or new feature they added but the panning sucks now. when I hold right click and try to pan and let it go theirs a slight delay where its still panning even when im not panning anymore. its so annoying, anybody has the same problem?
Can you run SystemInfo in Rhino and copy paste the results here?
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Educational, build 2023-12-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 2070 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 6-23-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.40
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-23-2023
Driver Version: 31.0.15.3640
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\DJ\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22353.1023
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
Hi Demetrio -
What happens when you disable that plug-in and restart Rhino?
I have the exact same problem. Noticeable lag/stuck/delay when panning. I had the RH8WIP since roughly last summer and this issue appeared only after I updated to the final release version, recently. Maybe it was one release version before or after, I can’t remember exactly. This is a very annoying bug.
SystemInfo
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Testversion, build 2024-01-09
Expires on: 2024-01-30
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.15
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 12-6-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.33
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 12-6-2023
Driver Version: 31.0.15.4633
Total Video Memory: 10 GB
C:\Users\Chris\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.24009.15001
how do u do that? also i cant even pan anymore, my right click is not working
Clarification:
This doesn’t happen every time I pan, just like once or twice a minute or so. In those moments it’s not just pan but also mouse zooming. Likely any input, just pan and zoom make it most apparent. The rhino viewport simply gets stuck for about one second, then catches up.
I never had this before and it doesn’t appear to be related to file saving. I can’t say for sure but I think it is a rhino display issue.
@hitenter what’s your latest _SystemInfo, could you send a file that shows the lagging behavior?
I now know where the hangs/lags came from. To make it short, it wasn’t Rhino at all.
I use the Logitech MX Vertical mouse since a little over two years and the buttons of this mouse started failing. Since I use mostly the keyboard and shortcuts in Windows, I can avoid most of the mouse drag&drop actions. So outside of Rhino I wasn’t using the mouse for click&drag gestures that often. That’s why I only noticed it in Rhino. Two weeks ago, I noticed the problem in Windows too, since it got worse. It’s this problem here, here and here. Last week I fixed the problem, now the mouse works again and I can confirm that it had nothing to do with Rhino, it was all just the Logitech mouse slowly starting to fail almost exactly after the warranty ran out.
I’m very sorry for attributing this to Rhino. I’m a little embarrassed now :cry:
At least I managed to fix my mouse.
