PanelingTools UI missing in Rhino 8 for Mac
I’m experiencing an issue with PanelingTools on Rhino 8 for Mac.
The plugin seems to be installed and loaded correctly because I can run commands like ptGridArray from the command line without any issues. However, I cannot get the PanelingTools menu to appear in the top menu bar, nor can I find the PanelingTools toolbars in the Library or Containers.
What I’ve tried so far:
  • Running a PT command to “force-load” the menu (Command is recognized, but no menu appears).
  • Checking the Plug-in Manager: PanelingTools is “Loaded” and “Enabled”.
Could you please advise on how to manually restore the PanelingTools menu and toolbars in Rhino 8?
Thanks!
You can follow below steps to open the toolbar of PanelingTools in Rhino 8 Mac
PanelingTools.rui (450.4 KB)
It worked, thank you so much!
Is there a way to get the paneling tool menu? I followed the instruction and installed the toolbar but I would like to have also the menu option, (rhino 8 using MAC)
Thanks
Sorry for late reply. I put this on the list as PT-209 Paneling tool menu for Rhino Mac
