Panel scale error on a diagonal mesh
Hello everyone! I want to put a diagonal structure on a normal mesh. I managed to do that, but I can’t get the new curves scaled and I can’t lift them. Does anyone know what I have to change, or which way I can still take?
also the problem is, that the panels at the edge are not scaled.
In the end my facade should look like this:
Shell_Structur_1_re.gh (84.7 KB)
Thanks
All your curves are invalid.
I think you made this thing much more complex than it needs to be using Paneling Tools.
You have all your facets from the polysurface (you could also avoid that conversion with Face Boundaries)
So use those edges directly.
Shell_Structur_1_re.gh (91.1 KB)
Thanks for the answer. It worked :slight_smile:
I have one more question, when i connect the structure to my ladybug script, it only looks at every second panel, it does not look like your script, do you know why?
[Shell_Structur_1_re.gh|attachment](upload
Lageplan+Austockung.3dm (5.7 MB)
://7iTrr0L0YpM7Kp0mcVWOEAqdidF.gh) (86.3 KB)
Thanks for your help :slight_smile:
