Panel positions
Hi I like to stack the layer and properties panels on top of each other in one column on the right of the screen. V6 does not keep this arrangement but puts the two panels side by side each time it opens. Is this a bug?
Eric
That sounds like the preferences file is not being overwritten properly when you close Rhino WIP. Can you try right clicking the Rhino WIP application icon and choosing “run as administrator”? Then rearrange the UI and close>restart. Any luck?
That seemed to work Brian, thanks
Eric
Hmmm… Is that all there is to it?
– just tested to be sure and, no, that doesn’t do it.
https://mcneel.myjetbrains.com/youtrack/issue/RH-35026
I don’t experience that bug here in the WIP myself. It is still open though so perhaps @JohnM knows more about why some users, yourself included, may still see it.
