Not sure if this intended, but when I open the tab-panel list it pops up on the second monitor wich in rather inconvenient. as they are spaced apart. I’d expect it to popup inside the Rhino Window in the current monitor space…over the current tabs.
-WIllem
HI Willem - I see that too - a right-click on an existing tab does what I think you want, so we should be able to fix it.
https://mcneel.myjetbrains.com/youtrack/issue/RH-37480
thanks,
Correct!
Thanks
This will be fixed in the next WIP.
John
RH-37480 should be fixed in the latest WIP. Please give it a try.
