Hi everyone! ![]()
I’m a Grasshopper beginner and I’m 99% done with a 3D-print toolpath — just stuck on one ordering issue.
What I have:
A horseshoe-shaped structure printed in a spiral. For each of my 294 layers, I have:
An outer wall curve
An inner wall curve
Connectors between them at the tips
A zigzag infill curve in the gap
Connectors from the zigzag to the walls
All the geometry is correct and the pieces touch each other where they should. I’m joining everything with Merge → Join Curves.
The problem:
When I plug a List Item into the joined output to step through the curves, I see that the printer would do all 294 outer walls bottom-to-top first, then all 294 zigzags bottom-to-top, etc. — instead of interleaving them per layer like a real print needs:
wall layer 1 → zigzag layer 1 → wall layer 2 → zigzag layer 2 → …
So my Merge is stacking the input lists end-to-end instead of interleaving them per layer. I think this is a data-tree issue with how my inputs are structured (some flat, some grafted, etc.).
What I’d like:
Whatever the right way is to make Grasshopper combine these inputs in per-layer order so that branch N contains all the pieces belonging to layer N, in the right traversal order — and then Join Curves can fuse each branch into one continuous segment.
I’ve tried Weave and Entwine and various combinations of Flatten/Graft/Simplify on the inputs but I keep getting either too many branches, branches with wrong contents, or back to the stacked order.
File attached. If anyone could take a quick look and show me the right combination of components and tree settings, I’d be incredibly grateful. I’m not looking for a fancy solution — just the standard “interleave N lists per-index” pattern.
Thank you so much! ![]()
tester.gh (61.5 KB)
