This is very strange. If I create a new Layout and name it, then change the orientation from Portrait to Landscape, the page dims change but the Layout is created in Portrait. If I change the orientation, first, then name it, it works as it should. I have tried clicking on other items in the dialog box to see if the change of orientation did not “take” but that does not help.
Is this normal?
pascal
(Pascal Golay)
May 14, 2020, 3:31pm
2
Hello - It seems to work here - I click + on the viewport tabs, and in the dialog, I first name my layout and then switch between portrait and landscape, then without doing anything else, hit OK - the layout is oriented as I asked - that is what does not work for you, correct?
Exactly what does not work. It’s very consistent, too. If I do not name the layout, it works. If I delete the layout and create a new one, it behaves the same way.
I suppose that this is normal, but if I change the orientation after the Layout is created, the viewport rectangle remains in the old orientation.
I just tried it in Rhino 5. Works fine. Just not in 6.
(6.25.20114.5271, 4/23/2020) I knew you would ask.
pascal
(Pascal Golay)
May 14, 2020, 3:43pm
5
Yes, this is expected but not the original complaint,… can you run SystemInfo in Rhino and post the results? It’s always good to look for plug-ins that might be getting in the way.
Rhino 6 SR25 2020-4-23 (Rhino 6, 6.25.20114.05271, Git hash:master @ f35d7ded15ec317635ced435d8df84327397038d)
License type: Commercial, build 2020-04-23
License details: Cloud Zoo. In use by: Gizmobreaker ()
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: MLAP7
Hybrid graphics system.
Primary display: Intel® UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 5-28-2019 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P3200 (NVidia) Memory: 6GB, Driver date: 10-23-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 432.06
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-23-2019
Driver Version: 26.21.14.3206
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Users\Marty\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\BoltGen\BoltGen.rhp “BoltGen” 0.0.0.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.25.20114.5271
No help in the SystemInfo, I guess?
pascal
(Pascal Golay)
May 15, 2020, 9:18pm
8
Hm. No. I see BoltGen but I’d be shocked if that is getting its oar into Layouts. Can you try the V7 WIP and see if that behaves similarly?
https://www.rhino3d.com/download/rhino/wip
It works in 7 WIP. I think. I tried with a new model and with an existing model that had 4 Layouts, already. Here’s the SystemInfo:
Of course, BoltGen in not installed. I seem to recall that it wasn’t guaranteed to work with Rhino 6 so I’m not super confident that it won’t break the WIP.
Rhino 7 SR0 2020-5-12 (Public Build, 7.0.20133.11585, Git hash:master @ 80ff3fd5d5ccdf5df25139f27f24ec3de87b99b4)
License type: Commercial, build 2020-05-12
Expires on: 2020-06-26
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 7 WIP\Plug-ins\Commands.rhp “Commands” 7.0.20133.11585
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.20133.11585
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.20133.11585
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 7 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.20133.11585
C:\Program Files\Rhino 7 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.20133.11585
C:\Program Files\Rhino 7 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 7 WIP\Plug-ins\Displacement.rhp “Displacement”
