Hi @eirannejad,
when I define the requirements inside a module that is loaded by a main entry file, the required packages do not get installed. The example below throws a module "firebase_admin" not found exception
To me it seems logical to keep the requirement statement #r: firebase_admin
in the same file as the import statement. Otherwise all the files that import ‘my_firebase_module’ should contain the same requirement statement #r: firebase_admin
, this may become difficult to manage for many scripts and many dependencies
Maybe I am not understanding the mechanism correctly, so I hope you can help clarify this
Thanks,
Tim
# main.py
from my_firebase_module import some_function
def main():
some_function()
if __name__ == '__main__':
main()
# my_firebase_module.py
"""Requirements"""
# r: firebase_admin
import firebase_admin
from firebase_admin import credentials
from firebase_admin import firestore
def some_function():
# ...module functions go here
print('execute some function')
