cfee
March 16, 2026, 10:58am
1
any suggestions, as package manager won’t load. Worked before. Didn’t run any recent update, both rhino nor windows
Rhino 8 SR29 2026-3-4 (Rhino 8, 8.29.26063.11001, Git hash:master @ bbd126f84fcdaf7a974615b7c9f4f8667571c147)
License type: Commercial, build 2026-03-04
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce RTX 3080 Ti Laptop GPU (NVidia) Memory: 16GB, Driver date: 11-6-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.14
- Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: NVIDIA GeForce RTX 3080 Ti Laptop GPU (NVidia) Memory: 16GB, Driver date: 11-6-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.14
Secondary graphics devices.
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 1-27-2022 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-6-2024
Driver Version: 32.0.15.6614
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.234\Ladybug.RH.Loader.rhp "Ladybug.RH.Loader" 1.38.234.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.52.20\Pollination.RH.Loader.rhp "Pollination.RH.Loader" 1.52.20.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
wim
(Wim Dekeyser)
March 16, 2026, 11:46am
2
Dag Chris -
Could you run Rhino with logging enabled and send us the text file that is produced?
→ Enable Debug Logging in Rhino for Windows [McNeel Wiki]
cfee
March 16, 2026, 11:55am
4
cfee
March 16, 2026, 11:57am
5
installing a yak file by just drag n drop works.
I tried switching between NETCore and NETframework v8 / v7, doesn’t change anything
cfee
March 19, 2026, 7:29am
6
Hi @wim , do you have any updates on this topic yet?
I uninstalled rhino and reintalled it, but sll connection error stays.
cfee
March 30, 2026, 9:18am
7
anyone else at rhino can give me advise. Seem it’s related to some setting in my browser/windows system
Even after full uninstall, including all left-over folder and reinstall, i still get this message that SLL connection cannot be established.
I tried it with R9 WIP, and that also doesn’t load.
wim
(Wim Dekeyser)
March 30, 2026, 9:45am
8
Dag Chris -
We have a person in the Barcelona office with the same issue and have been trying to figure that out. We added more information in debug logs in 8.31 but so far that hasn’t helped fixing this.
I’ve added this conversation to the thread.
cfee
March 30, 2026, 10:15am
10
Ok, thanks for the update.
what i tried thus far (unsuccessfully)
SetDotNetRuntime, changed from NETCore to NETFramework (or vice versa)
windows firewall > added outbound rules for Yak and Rhino exe
set windows time to automatically instead of manual (for sll handshake)
in browser I can see txt file in https://yak.rhino3d.com/info
run as admin command “certutil -urlcache * delete” to clear .NET cache
network & internet proxy: turned On / Off “Automatically detect settings”
Check if it was related to having software like Python (Anaconda), Git, or curl is installed, run in PowerShell “Get-ChildItem Env:SSL_CERT_FILE, Env:CURL_CA_BUNDLE, Env:REQUESTS_CA_BUNDLE -ErrorAction SilentlyContinue” but result was blank
UncheckedCheck for publisher's certificate revocation +
Check for server certificate revocation in Internet Properties
I don’t have VPN or 3rd-party antivirus
cfee
March 30, 2026, 10:45am
12
Seems i was to optimistic only seems ti work for couple of seconds after a windows restart. so possible the above had nothing to do with it
all in R8 SR29
jeremy5
(Jeremy)
March 30, 2026, 11:32am
13
It is possible that McNeel are doing something with security at their end. There’s another issue (albeit with 8.30) here: Bongo fails to load in latest Rhino 8 release
cfee
March 30, 2026, 12:07pm
14
@wim it’s a long shot but it seems to be related to Intel Killer Performance Suite. It intercepts SSL handshakes to see what kind of data is being sent so it can prioritize games. When I disabled the Prioritization Engine i could load the Package Manager and install all needed plugins
Open the Killer Intelligence Center
Go to the Settings
Turn OFF the Killer Prioritization Engine .
Turn OFF Auto Bandwidth if it is on.
Restart Rhino and test.
crz_06
(crz_06)
August 31, 2026, 3:58pm
15
@wim was this an intel or mcneel issue, i.e. should it be add to bug report?
wim
(Wim Dekeyser)
September 1, 2026, 6:40am
16
Dag Chris -
When someone installs an application on their system that controls access to the internet, Rhino is not going to bypass that in any way.
