Override overloaded method
Hi all
After a post on it.discourse about making a script play a sound, I tried to script this
But was unable to translate this class to IronPython
public class SineWaveProvider32 : WaveProvider32
    int sample;
    public SineWaveProvider32()
        Frequency = 1000;
        Amplitude = 0.25f; // let's not hurt our ears
    public float Frequency { get; set; }
    public float Amplitude { get; set; }
    public override int Read(float[] buffer, int offset, int sampleCount)
        int sampleRate = WaveFormat.SampleRate;
        for (int n = 0; n < sampleCount; n++)
            buffer[n+offset] = (float)(Amplitude * Math.Sin((2 * Math.PI * sample * Frequency) / sampleRate));
            sample++;
            if (sample >= sampleRate) sample = 0;
        return sampleCount;
The problem, as far as I can tell, is I don’t know how to make IP override the right overload of
Read()
Looks like it is overriding
WaveProvider32.Read( byte[], ... )
instead of
WaveProvider32.Read( float[], ... )
( Well … at least this is my understanding of the problem … )
Is there a way in IP to specify which method from an imported C# library it has to override ? ( For overloaded methods )
This is the IP code that fails, complaining about an impossible cast from float to byte:
import math
import time
import clr
clr.AddReferenceToFileAndPath( 'C:\\lib\\NAudio.dll' )
import NAudio as nau
class SineWaveProvider32( nau.Wave.WaveProvider32 ):
  def __init__( self ):
    self.Frequency = 1000
    self.Amplitude = 0.25
    self.sample = 0
  def Read( self, buffer, offset, sampleCount ):
    sampleRate = self.WaveFormat.SampleRate
    for n in range( sampleCount ):
###### offending statement below
      buffer[ n + offset ] = float(
          self.Amplitude * math.sin( 2 * math.pi * self.sample *
          self.Frequency / sampleRate ) )
      self.sample += 1
      if self.sample > sampleRate:
        self.sample = 0
    return sampleCount
waveOut = None
def StartStopSineWave():
    global waveOut
    if not waveOut:
        sineWaveProvider = SineWaveProvider32()
        sineWaveProvider.SetWaveFormat(16000, 1) # 16kHz mono
        sineWaveProvider.Frequency = 1000
        sineWaveProvider.Amplitude = 0.25
        waveOut = nau.Wave.WaveOut()
        waveOut.Init( sineWaveProvider )
        waveOut.Play()
    else:
        waveOut.Stop()
        waveOut.Dispose()
        waveOut = None
seconds = 2
t0 = time.time()
StartStopSineWave()
while True:
  t1 = time.time()
  if ( t1 - t0 ) > seconds:
    break
Thanks
