I need to offset curves in a particular frame. The curve to be offset is obtained from the solid trim component. Sometimes there is one curve sometimes there are two. I am not able to get curves properly for my geometry. multiple_cavity_curve_offset.gh (128.0 KB) sample_geom.3dm (272.9 KB)
I have uploaded the programme file in which data is internalised and the respective geometry in case. I need the following ouput for a single and double cavity respectively shown in the image.
Thank you man. I didn’t knew the polyline offset component before. Also i like the idea of using bounding box instead of using individual frames. I will try to implement it in my other programmes also. Thank you very much.
