I still don’t get you, What I understand is that you need the sections of the tweened curves that are confined within each cell (defined by its perimeter) and you want them grouped by cell.
(in your example 4 groups, and also some might overlap)
no?
I just need the tweened curve shattered in a way that the green/red sub curves are created (a big plus is having them sorted as one cell). Forget about the blue outline.
Once I have them shattered I can plug them into my main script to create the 3d pattern, which needs these 4 curves as input.
Sorry man, this is over my level. I guessed breaking the curves into sections and using relative items would do the work but personally I’m not that proficient with the notation.
I hope somebody else will help you!
I don’t want to hijack your question but it might be relevant:
I’ve found this link and studied it, but never found a way to apply it as input with the tree modules (tree item/relative items etc)
I’m bringing it up because I think this is the way forward in this case…
I would have written a script here, since this is easier as dealing with tree components. If nobody can or is willing to help, I will do it tomorrow and post it here.
