is there a way to output in Grasshopper the username of the user logged into the computer OR somehow extract the USERNAME in the UserObjects folder name…
C:\Users\USERNAME\AppData\Roaming\Grasshopper\UserObjects
Create a C# script component, use
thanks jesterKing…within the component, besides the “public static string UserName { get; }” code, is there any additional code that needs to be added or a “return” added, as I’m not getting an output currently. any help is much appreciated!
I couldn’t be bother to find out how to add new assemblies to C# scripting component, so I did it just with a Python component. No inputs, and only one output called username
, and code:
import System.Environment as env
username = env.UserName
username.gh (4.8 KB)
awesome…worked perfectly…thanks!
