I’m working on a component that outputs geometry that is much larger than the input geometry (see below, a grid of 20x20 rectangles gets clipped). Is there a way to prevent this?
I believe you should override the ClippingBox property:
https://developer.rhino3d.com/api/grasshopper/html/P_Grasshopper_Kernel_GH_Component_ClippingBox.htm
I tried that, but that does not seem to work.
