Ostrich: patent drawings from Rhino models, live in the viewport
I just released Ostrich, a plugin that turns Rhino models into patent drawings, live in the viewport.
Features
  • Clean outlines. Outline and creases of the model; surface seams are never drawn.
  • Three shading sources. Light, cast shadow and surface curvature.
  • Three styles. Each source as stipple dots, lines or cross-hatch, each on its own switch.
  • Line control. Lines along waterlines, slices, flow or curvature.
  • Dot control. Random or on a grid, in six shapes: round, square, ring, triangle, X, asterisk.
  • Light side. Light from the left or the right.
  • Trademark silhouette. Contact patch and solid black silhouette, filled from the angle you set.
Free trial, then US$149.
Ostrich on Food4Rhino
Questions, bug reports and sample models welcome in this thread.
I’ll be posting an update soon. It will include the new ‘photograph’ style and rendering engine built from scratch.
Ostrich 0.2.0 is out.
Photos. Ostrich now draws grey photos of the part on a white page with its own ray tracer, built from scratch, running on every NVIDIA graphics card in the machine (OpenGL on other cards). One light, fixed to the camera, so every view is lit the same way; glass parts drawn as glass. There is a live photo display mode in the viewport, and a showcase command that photographs the part from the 26 directions of a cube (6 faces, 12 edges, 8 corners) and lays the pages out as a PDF. The two sheets below are from that command.
Install changed. The old .rhi installer could not install the plug-in at all (the Rhino installer engine cannot read .NET 8 plug-ins); if it told you “not compatible”, that was why. 0.2.0 is a package: in Rhino 8 type PackageManager and search ostrich, or download the zip from Food4Rhino and double-click the .yak inside. Restart Rhino, then type Ostrich.
Full list and download: Ostrich | Food4Rhino
