Hi Charles - this depends on whether Planar is active in the status bar. If Planar is on, then there is a ‘virtual’ CPlane passing through the last selected point and Project goes to that plane.
I think Project is defeating you.
With Project turned on with Center, when you put your mouse over the circle, Center finds the center, and project drops it to CPlane zero.
For a Move you would need to start Move and grab the center of the Circle with Project turned off. That’s the point you’re moving from.
Then turn on Project and click the circle again. With Project on for the 2nd pick, the circle center is moved to CPlane Zero.
Another story, often asked in trainings:
Why do I need to touch the circle, why can’t I simply go to the center?
While I can imagine the reason, the question is a good one.
It is possible:
That’s exactly my answer.
I say ‘How do you grab a hoola hoop ring from the floor? Do you grab it in it’s center?’.
Nevertheless the center snap could be smarter.
Why not search the visible area for centers and let the one win where the mouse is?
This approach could be restricted to arcs and circles.
For closed polylines it could be confusing.
Hi Charles - I guess the advantage here is that you can specify what center to look for - if there are multiple objects with centers near each other, searching in the center is going to be harder than finding the curve you care about at the curve itself.
