Osnap not working with .fbx import
I opened a .fbx file in rhino, and it opened just fine, however I am not able to use osnap on any of the meshes. When I create a separate shape in the same file, however, I’m able to snap to that shape. So this makes me believe that there is an issue with the .fbx meshes.
Hi Isabelle, with Meshes you will need the Vertex snap vs End.
Well, that seemed to be the issue. Thanks!
@Isabelle_Brehm1 in case it helps, you can snap to some mesh locations besides vertices
but you may want to use this with caution as it can interfere with normal End/Near/Mid snaps in a mixed model and drive you nuts…
