i have a similar problem with OSnap like this topic (Osnap not working). I work with VA, and after refreshing the 2d plan, OSnap ist not working any more… also when you insert a new 2d plan, the problem is quite the same. When i explode the 2d plan into lines, it works …
Hi @ERahjes, I am not able to reproduce this behaviour. Does this always happen? I mean, are you able to reproduce it? Does this happen in any viewport? with any display mode? on 2D plan views only? or 3D geometry as well? If you can send the model to visualarq@asuni.com indicating the steps to follow so we can try to reproduce this behaviour.
Thanks,
@ERahjes which VisualARQ version do you have? we fixed a bug related to this issue in VisualARQ 2.0.17, so make sure you have this version: http://www.visualarq.com/download/
