Are the extra space between some of the check boxes/labels intentional?
V6
V5
When they are positioned in-line as shown above, it would be great to have as many check boxes exposed as possible.
Thank you,
Steve
V6
V5
Thank you,
Steve
Hi Steve - yeah, I see … I dunno, I’ll see if we can tune that up.
https://mcneel.myjetbrains.com/youtrack/issue/RH-43086
@spb - Mikko’s comment about the reason for this:
“that’s because the first three have alternate subobject strings, Points/Vertices, Curves/Edges and Surfaces/Faces. If the spacing was made tighter when the longer versions are not showing, all items to the right would have to move around every time Sub-objects is checked or unchecked.”
thanks,
