OrientonCrv
Question in using orientoncrv command.
I’d like to orient a closed curve on an open curve.
After it gets oriented, I’d like to rotate or Flip in X or Y direction.
But, I can’t get to the flip menu unless I press perpendicular option first.
any way to get the Flip/Rotate option without changing the perpendicular alignment?
Hello - currently, no - are you asking to be able to flip from one side of the curve to the other?
(One thing I see here is that the command seems not to be consistent in which direction if places the object on the target curve… I’ll look into that.)
RH-57534 Curve pick determines object direction
RH-57534 is fixed in the latest WIP
Thanks!
It seems fixed in the new WIP.
Thank you for your support!
