Orientation of planarsrf
Hello, I would like to know more about the orientation of planarsrf, as sometimes I found it forms the rectangle surface “rotated”. Is it determined by my input curves? Thank you.
Orientation of planarsrf.3dm (150.2 KB)
Yes, Rhino has some sort of internal “magic formula” it uses to figure out the orientation of the planar surface. It doesn’t always make it the way you expect. If the orientation really matters to you, make a rectangular plane surface first and trim the surface with the curve.
