having spent an hour orienting an obj to get it vertical and hrz and at 0,0 etc.
to realise it lacks fine detail of original in Agisoft. its a mushy mess,
so import decent one from V8
need orient3pt it to the first one,
select object to orient and its a bright yellow mass.
How can I pick a detail on both this and the original obj when it ceases to show the image as such ?
Just how can orient3pt be used on a mesh ???
Hi @Japhy
need to see the detail on the object to pick 3 points, such as middle of a rivet, or a spider poop, etc.so yellow or green or whatever, doesnt allow viewing of the details.
Norbert’s suggestion is what I do to orieint dense meshes.
Place reference points on the subject mesh at three locations.
Place points/lines in the desired locations.
Start Orient3Pt
Select the subject mesh
Turn off the layer with the subject mesh or hide the subject mesh
Select the reference and target points
Complete Orient3Pt
Make the mesh visible
Hi, I also do that, usually turning off mesh layer, making sure my ref points are on a separate layer.
working blindish.
I wish though the grey mesh didnt appear as soon as I start to move anything.
Steve
draw proxy-geometry on separate layer Group this geometry with the mesh !!
turn of the mesh 's layer
do the transformation with the group, by selecting the proxy geometry (rhino 9 will “ghost-display” the mesh)
