Is it possible to orient things to various surfaces by taking one time the option
In general, the answer to your question is yes.
It is not clear what you are trying to accomplish. Could you provide more information? Perhaps a sketch? Are you looking for a pure Rhino solution? Or scripting? Or grasshopper?
Not sure if I can help, but with more information I’m sure somebody here can help you.
-Kevin
No this is not possible afaik, but I do have a script somewhere to orient to multiple objects at the same time by taking the underlying mesh if that helps.
It will be greatful if you share the script with us
Thanks for your reply
In diamond jewelry when we orint a prong to various surfaces each time we have pick the option and pick surfaces again and again.i am trying to jump one surface to another surface not taking the option again and again.
do you have an image or a model that you can share? you could still try to create one approximate patch surface from several regions.
It’s been almost 10 years since I published this, but maybe you still find it helpful for now:
–jarek
Thanks a lot
@Jarek 's looks more sophisticated, but here it is:
orient_on_multiple.py (3.8 KB)
