Orient On Polysurface
Hi!
It is often necessary orient on the polysurface.
But unfortunately I can not find this tool in Rhino
Can solve this problem by using scripts or macros?
Also long overdue issue of OrientOnSrf
almost always need a copy of the object.
I wrote a macros but Copy=Yes does not work for OrientOnSrf
_OrientOnSrf
_Pause Copy=Yes
Hi! Use _Drape (in shaded mode) to add a temporary surface on which to orient.
Add dash to suppress the dialog for _OrientOnSrf, in which case you can set Copy to Yes:
-_OrientOnSrf _Pause Copy=Yes _Pause
Hi 0netech!
Thank you for drape! It’s a good idea!
But the macro does not work. The object is not copied.
It also adds unnecessary settings with scaling and rotation of the object on the surface
