I fail to orient a CP plane on an extrusion surface
If I explode the extrusion on a number of surfaces then I can orient the CP plane in the wanted surface all right.
Is this normal?
(even if it is normal, IMHO the orient plane on surface should be able to detect the surfaces of an extrusion element without the need for the explosion)
Now I see that it sometimes works sometimes not…looks like if the camera is too close to the object it’s more difficult to work,
On the uploaded file try to orient the CP on the large inclined front face
