Orient block on object (mesh)
Trying to figure out simple task in grasshopper. How to align or orient blocks on a mesh ? I unwelded a mesh and used the faceN command to illustrate what I am looking for. Instead of creating curves, I would like the block to be centered in the triangle of the mesh.
Thanks,
Hi gimmy -
Something like this, perhaps?
Hi wim. Exactly but with a selected block that as a base shape of a cylinder but with more complex details. Thanks wim
Are you using Rhino 8?
Yes. Or i can use 7 also.
In Rhino 8 you can use the new Grasshopper Rhino components to place blocks.
Nice will try that. Hope it will work with orient base point perpendicular to normals.
If it doesn’t work, post your files with the relevant geometry.
Hi Wim’s definition works great. But when I try block it does not work as I want. See images and files. Thanks,
TEST_PISSENLIT_2.gh (11.5 KB)
TEST_PISSENLIT_2.3dm (273.5 KB)
Hi gimmy -
This seems to work:
TEST_PISSENLIT_2 - block instances.gh (8.7 KB)
thanks a lot wim. It’s perfect, You rock ! :wink:
