Hi all
the attached Python Script orients and rotate3d objects : it’s more intuitive of Orient3pt
#-*- encoding: UTF-8 -*-
#********* Copia e orienta oggetti e gruppi********
#****** Write by Ing. Vittorio Carlotto ***********
#****** carlottovittorio@gmail.com 20-12-2013 ****
def ImportaOrientaRuota(stroStart):
arrplane=rs.ViewCPlane
rs.EnableRedraw(True)
if stroStart==None: return
p1,p2=rs.GetPoints(True,False,"1° reference point","2° reference point",2)
if p1==None: return # se non prendo punti
if p2==None:return
p1ob=rs.AddPoint(p1)# 1° punto che oriento e mi serve per ruotare
p2ob=rs.AddPoint(p2) # 2° punto che oriento e mi serve per ruotare
rs.UnselectAllObjects()
stroStart.insert(0,p2ob)
stroStart.insert(0,p1ob)
while True:
stro=rs.CopyObjects (stroStart) # copia degli oggetti da rototraslare
rs.SelectObjects (stro) # seleziono oggetti copiati e punti
####### oriento oggetti e punti ##################
rs.Command("_Orient _Scale=_No _Copy=_No w"+str(p1)+" W"+str(p2)+" _pause _pause _enter",False)
np1=rs.FirstObject()
ccnp1=rs.PointCoordinates(np1)
np2=rs.NextObject(np1)
ccnp2=rs.PointCoordinates(np2)
rs.DeleteObjects((np1,np2))
all_Objects=rs.LastCreatedObjects()
if all_Objects==None:
rs.DeleteObjects(stro)
rs.DeleteObjects((p1ob,p2ob))
break
rs.SelectObjects(all_Objects)
rs.Command("_Rotate3d w"+str(ccnp1)+" w"+str(ccnp2)+" _Copy=_No",False)
print "Enter Enter for End"
stroStart=rs.GetObjects("Select objects ")
Ciao Vittorio
