Rhino Wip 6.
Could you order better, more coherently, the various toolbar icons?
If we look at the “edit surfaces” icons, for example, default is: filletSrf, then extend Surface, then chamfer and then fillet again … Does it seem consistent?
For example, the various “curve offset” tools, order them one after the other! The vaious “fillet surface” icons, one after the other! do not be random!
Also, avoid redundancy of icons: in curve generation tools, why is there a “TweenCurves” command? but it should only be in the toolbars inherent in curve editing tools … (Intermediate curves are generated only after creating two curves, so I do not think it’s the right place to be).
