Organic Shape / Lots of Bridging SubD Approach?
I’ve been seeing a lot of organic shapes like this lighter case.
Curious for the SubD experts here how ya’ll might model this? Simple subD cylindrical primitive to start? Start from scratch with just a SubD plane and work your way along? Some sort of multi-pipe trick??
I can find virtually no online tutorials of similar shapes, if anyone has come across anything… :confused:
Some additional examples below:
As always, ya’ll are the best and thank you in advance!
You’d better start with a cage made of curves and the thicken it with _Multipipe.
After you can improve the shape by sculpting it like in the images.
I’d start with a network of lines to Multipipe.
Then Boolean the inner shape to fit the lighter or whatever it’s going to fit around.
Hello
to my point of most these shapes needs a different work flow.
For the middle one you can quad remesh the rough shape you want and delete some faces then thicken (offset) and use some subdivision /subd.
From
To
to
some smoothing
Here just a play there using some clustering technique
wow, really neat result on the last. Thanks this is really helpful. I’ll play with both the broken down re-mesh to subD.
Curious when you say clustering techniques, are you using GH procedural commands like K-Means? Thanks.
Yes I am using Grasshopper and my own tool for that, some of them are in Nautilus plugin. See this post.
Also by the way your questions allowed me to think on the subject and make a new tool that soften the jagged naked part of a mesh, but it make sometime bad faces, so I have to take care of that. The naked edges are converging toward the smoothed polyline made from naked edges.
Explanation with vectors, you can see that some quads are transformed to 2 triangles
Method 1
Method 2 mesh points go to the closest point on polyline (not the best)
This can be achieved with regular NURBS surface after manual adjustment of the control points.
Check the skull and the totem figure in this post:
ok some great approaches!
@geemix - cool alternative to multipipe that follows the contour of the underlying shape perfectly.
I tried to experiment today with a multipipe GH workflow to “replicate” the lighter cover, and got to here before putting a pin in it.
I produced this in GH by:
  1. Randomizing point generation / location around the surface
  2. Connecting the points with line segments using 3D proximity
  3. multipipe → subD
Then I tried to manipulate the “stretch” at a ~30 degree angle relative to the XZ axis, but found the best luck manipulating the subD in Rhino after baking it :confused:
Still lacking the “uniform chaos” that is captured in the lighter image, unfortunately. Open to any feedback!
