Ordering docked panels not working anymore
I remember being able to order panels (tabs) siting in a same docked panel.
I cannot to it anymore…
As soon as I grab a panel tab, it becomes a floating window.
If I add a second panel in the newly created floating window, ordering tabs is possible.
Not possible when docked
Possible when floating
Regards
Rhino 8 SR17 2025-3-7 (Rhino 8, 8.17.25066.07001
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.19
hi @lahos pls run _SystemInfo in Rhino and post back the result.
Rhino 8 SR17 2025-3-7 (Rhino 8, 8.17.25066.07001, Git hash:master @ b14fcd901289f8715631debb308bc919a4988e07)
License type: Commercial, build 2025-03-07
License details: Cloud Zoo
.NET 7.0.19
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 6-10-2024 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 2-25-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.60
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-25-2025
Driver Version: 32.0.15.7260
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
S:\Code\Rhino\plugins\CSCommandOnKey.rhp “CSCommandOnKey” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\Import_PDF.rhp “PDFReader”
to be sure can you disable CSCommandOnKey and see if that resolves the issue?
If that is not it, do you have your layout locked by any chance?
Disabling my plugin didn’t work.
In safe mode neither.
And yes, I’ve already played with the Lock Docked Containers with no luck.
I tried to create a new dock container and move all my panels to this new one and it works.
It seems my current/old containers are locked but not the new ones ?
