Order wise connection
I am Shasan. I have a question regarding the connection of the components shown in image. The aim is to run a simulation for each input group shown in left. For that I have to connect the components from left to the components of connector group and each time only one group should be active/connected to run the simulation. When there is no such component in input group I have to connect line component which is there within connector group. The concern is that I have to connect each group from the left to the connection group on right manually every time I want to run simulation. Actually there are much more groups than this which makes it time consuming to do so. Is there any way it can be done automatically just by moving a slider or other similar component? Other alternatives than slider are also welcome.
Thanks,
Shasan
Try a stream filter.
You can try with Stream Filter
Trying,
Thanks
