I would like to know if it is possible to order this bunch of curves (they are not ordered in a logic way i think)tabicadas_2.gh (8.1 KB)
, I wato to create polilines in one direction and in the other so i can create a surface, Thanks a lot
Have a look at the attached… Weaverbird's Mesh from Lines
fr Weaverbir plugin is required.
http://www.giuliopiacentino.com/get-wb/
Thanks, i am going to see if i understand it, i will tell you. Thanks a lot
See the link in my posting…
Hello again, did you use grasshopper in Rhino 6? I have installed the weaverbird plugin and it happens the same, i can not see one component. Thanks a lot.
