Orbit/pan Multiple Viewports
Does anyone know a way to orbit/pan two Viewports simultaneously? I am hoping to have different layers on in each Viewport, so that I can compare them side-by-side in real time.
Thanks for the help!
Hi Juney - layer visibility does not apply per viewport in model space, only in layout details. - is that what you mean?
Hi Juney,
As Pascal said, in Model space you cannot separate layer visibility per viewport.
There is a possible workaround for this: you would need to create a custom display mode that doesn’t show the types of geometry you want hidden (or any geometry) and apply this mode per-object (_SetObjectDisplayMode command) to objects you want to hide in each viewport.
The fun part: a hidden _TestMooCow command would let you link/unlink two viewports to pan/zoom/rotate in sync.
hth,
Jarek
Thanks Jarek! _TestMooCow is exactly what I was looking for.
Haha, Testmoocow. :d
How do you know these hidden commands? Are there any others?
There are many, but most are useless to users and only a few are considered sufficiently non-hazardous to share, provisionally & with caveats, with the outside world.
by hanging out at this Forum :wink:
I have a list of twenty–seven ‘Test’ commands. Probably there are more, too…
[It would probably be unwise for me to post that list…]
I could see a nice black market developing…
I do want my cut.
