As of the most recent update, Rhino WIP (9.0.26160.12305, 2026-06-09) has a weird camera centre-ing issue. Instead of maintaining an even distance when orbiting around a selected object, it will go real close in one orbit direction, whilst in another go way out like it’s focused on something much further away. The result is it feels a bit drunk using it, and is very hard to orbit smoothly around selected objects. This has only happened as of this WIP - previous WIPs did not have this issue. Hopefully this can be addressed in the next WIP as this really interferes with moving around the model effectively. Zoom selected helps a little bit sometimes but the issue persists. Thanks.
The issue seems to be the selection. If I am zoomed into an area without anything selected, but then select a long element that is partially outside the viewport, the camera will try to orbit around the centre of the selected element, rather than the area I was zoomed into.
@sp3 sorry for the late answer. The default for rotation around gumball has changed in Rhino 9. You can set it to how it was in Rhino in the Gumball page
